Elecestim123
- MN
- Electrical Estimator
Hello all,
New to the forum. I'm also new to being an estimator. Working on a bigger project so I need to make sure I'm taking this off correctly. Engineer is allowing MC cable for branch circuits, but not for Homeruns. 'Homerun' isn't defined in the specs, and I know the NEC doesn't define it.
Typically I would think the 'Homerun' is the conduit and wire from the breaker to the very first device in the circuit. However, if I have several (Let's say 3 for this example) circuits in (1) conduit from the panel, is only the conduit and wire from the panel to the first device in the first circuit the 'Homerun'? Or is the 'Homerun' the conduit and wire from the panel ALL THE WAY down to the very first device in the LAST (3rd) circuit after also hitting the first device in the 1st and 2nd circuit?
Hopefully that question makes sense
