bhanson
New member
- sturgeon bay wisc
Hello All- I am the electrician at a manufacturing plant where we have 50+ punch presses- we are moving our equipment into a brand new building, and we are running into a very expensive problem: Our punch presses vary in age, country of origin, and tonnage capacity, and most of the presses do not have amperage draw listed on their tags, and some have no tags at all. With all this being said, the contractor for our new facility has his electrical estimator come in to calculate our loads in order to quote all of the bus duct, plugs, drop sizes ect..............here comes the problem-------- The estimator says that he sized the drops for the "tagged" machines from the amperage listed on the tag,, however for all the rest of the machines (which have no amperage listed or no tag at all) he used the main breaker( or main fuses) as the substitute for "tag" information and sized the drops according to that. He then proceeded to add up all of the 50+ machine calculations for the main bus duct sizing and ended up with 2000 Amp bus duct-- All of this puts our electrical costs close to $400,000!!! I have several key questions: First- if a machine has no tag, what is the most proper way to size the drop?? I don't see this addressed in the code... my problem with this is that we rarely use 20% of the capacity of the machine, so MUST we size the drop from the breaker /fuses (as this is never really spelled out in the NEC or NFPA) or can we size these machines based on our normal usage?? Secondly, although we have 50 + machine , only a fraction of them run at the same time, so is there an allowance regarding bus sizing with this in mind?? Sorry for the lengthy post, but this is a very expensive predicament, and any "wiggle room" is worth savings to us- Bill
