In PV solar installations, some say ground the negative and switch the positive. Some say to ground the positive. Some say to disconnect both neg. and pos. at the disconn switch and run a separate ground wire to a ground rod and use it to ground the boxes and the PV panel frames.
Another idea is to run the wire being disconnected in series through two simultaneous knife blade switches to control the arcing.
