bobbymari
- los angeles ca
We just did a 400 amp service for an apartment building. Service is located in same location as old service under a carport. The first 12' or so are a horizontal run to an lb up the outer wall. Just had a buddy tell me an inspector made him form and encase in concrete a similar install since it was ran horizontally under a living area.( This was in the 80's though. Everything is surface mounted with about 12 inches in between conduits and floor above. Are there any code references that prohibit unfused wires running horizontally on a surface mounted install. I'm aware of running unfused wires through a dwelling. i/e attics but this isn't the case.. Thanks in advance.
