Hospital as Hazardous area
The reason some of this is still in 517 is that some other countries still use flammable anesthesia and the NEC along with NFPA 99 is used as guidelines in some of these areas.
From NFPA 99
This material is being retained in this annex by the Technical Committee on Anesthesia Services for the following reasons: (1) the Committee is aware that some countries outside the United States still use this type of anesthetics and rely on the safety measures herein; and (2) while the Committee is unaware of any medical schools in the U.S. still teaching the proper use of flammable anesthetics or any health care facilities in the U.S. using flammable anesthetics, retaining this material will serve as a reminder of the precautions that would be necessary should the use of this type of anesthetics be re-instituted.
Roger
Even without flammable anesthesia - pure oxygen is present in most OR's. There is a push to use mixed air due to about 5 deaths/year due to oxygen fires.
Can you provide any back up to this? I am currious and would like to read these investigations
Roger
Roger
Unfortunately I read more than just a lot. I can't put my hands on that source atm. The source below for medical devices reports about 10 patient fires/year with pure oxygen as a common oxidizer source.
http://mdsr.ecri.org/summary/detail.aspx?doc_id=8197
The following quotes about 30 patient fires/year and recommends questioning any use of 100% oxygen in favor of 30% max oxygen. They are not trying to ban 100% but to question so 100% is not used without really needing it.
http://www.guideline.gov/summary/pdf.aspx?doc_id=3688&stat=1&string=open+AND+source
Electric, electrostatic, and laser devices are listed as common ignition sources. Mixed air typically needs a traditional fuel source like a flammable anesthetic. Pure oxygen turns a lot of non-traditional items into fuel like operating room tent drapes.
