Rick S.
- Oklahoma City, OK
I recently asked my class a code question concerning how many "hospital grade" receptacles were required in patient bed locations. After answering correctly, my student asked what the difference was between a "hospital grade" receptacle and a standard commercial grade 20 amp receptacle. After a little research, the best answer I came up with was that the construction of the "hospital grade" receptacle was made to ensure a better ground and the device was designed so that the attachment plugs would not be as likely to come out of the receptacle as easily. Is there anything that you can add to this? His next question was, "If they are concerned about machines not coming unplugged, why don't they use twist-locks?" and......."If it provides better grounding, why don't they have that on all devices since grounding is a concern for safety?"
