Re: Hospital Operating Rooms Power Supply
Bennie, although a fault on one side would only create a grounded system, the polarity of the system could be a concern.
The system should be wired as to disconnect both legs as far as switching in the premesis, and with the polarity issue, switching of tools and appliances could be a problem. Some tools and appliances have double pole switches and some do not.
If we were to eliminate GFCI's using this system we would have to know when we were becoming a grounded system to insure safety here. The characteristics would differ considerably between a metalic conduit and NM installation.
These are a couple of issues that would need to be made fool proof. (maybe minor maybe not)
I know we could keep GFCI's but, the safe level of operation could be a task to achieve and avoid nuisance tripping due to capacitve coupling (metalic installation) and individual leg impedance (overall leakage) adding to an imbalance between the two legs.
Roger
[ June 20, 2003, 01:42 PM: Message edited by: roger ]
