Has anyone tried the "Pipe Viper" pvc bender which uses no heat. You bend it cold.I have used a torch, spray bottle and rag.
I've played with them in a supply house. I wouldn't want to have to pull wire through the bends they make.Has anyone tried the "Pipe Viper" pvc bender which uses no heat. You bend it cold.
Larry, wouldn't you have to bend the pvc to meet 350.24 (Table 2 Chapter 9) requirements?I've played with them in a supply house. I wouldn't want to have to pull wire through the bends they make.
There has to be temperature limits on cold bending.
I would not allow them on a job unless I had concurrance from a PVC conduit manufacturer that it was acceptable and under what conditons.
I'de bet a large lunch that it won't work in NoDak in January.
Right, and those things won't.Larry, wouldn't you have to bend the pvc to meet 350.24 (Table 2 Chapter 9) requirements?
Anyone used or have any experience with the Hot Bend torch for bending pvc conduit? I am considering purchasing one. Thanks
Do you have a website that we can go to to look at this product? I goggled Hot bend torch and didn't get much.
Looks interesting. It also looks like a ham and cheese hot pocket would just fit in the wire basket.heres the link..http://www.hotbend.com/
