Dsg319
- West Virginia
- Wv Master “lectrician”
Some where in the code it states that anything that could become enegized must be bonded. At a IAEI class inspector brouht up a great point. If the stainless steel sink is feed by pex should the sink be bonded? Have to remember that not all houses have garbage disposals.In Phoenix, before I moved, it was required in Pex homes at the water main if the line running from the meter to the shutoff was copper. Made no sense to me since there was no metal interior piping. In some surrounding areas, you had to catch the hot and the cold at the water heater which is usually where we took the water bond. The reasoning being that, if you removed the water heater, there was no continuity.
Even if the house were plumbed with copper or steel, continuous to a metallic underground city main, the kitchen faucet wouldn't provide a reliable bond. It's often fed with non-metallic risers, is mounted between non-metallic gaskets, and/or has a non-metallic body.... If the stainless steel sink is feed by pex should the sink be bonded? ...
How would a metal sink be likely to become energized?Some where in the code it states that anything that could become enegized must be bonded. At a IAEI class inspector brouht up a great point. If the stainless steel sink is feed by pex should the sink be bonded? Have to remember that not all houses have garbage disposals.
Connected to a disposal unit?How would a metal sink be likely to become energized?
