electricalperson
- massachusetts
FPE fuse panel fed with a single phase 120/208 volt feeder. ambient tempature was 88 degrees. main fuse pullout was 141 degrees. 30 amp load on the panel. measured fall of potential across main lug to bus and had 100millivolt on each leg. im sure i know its loose connection. what do you guys think?
