CFLs are hard on Dimmers!
My previous post showed a 15 Watt CFL powered full on to show how the CFL draws a lot of current for a short time.
Now a follow up:
As has been mentioned the dimming range of CFLs is pretty poor and this is due in part to the fact hat the current "spike" is not drawn until after the peak voltage reaches ~125V.
For this reason very poor dimming is accomplished from 100% down to the 50% setting. Then from 50% downward the dimming works much better.
Here are two diagrams of a 23 Watt (75 watt equiv) CFL who's claim to fame is their dimmability (Greenlite).
The first is with the dimmer full on (dimmer is a unit with a neutral).
You can see the 1 amp current spike drawn after approx. the 60 degree point in the voltage waveform.
The second shows the dimmer at near the 50% setting.
Note the 4 amps current spike when the unit first turns on each half cycle.
When set at the 50% point you can easily audibly hear the dimmer humming.
Imagine a dimmer feeding 30 of these CFLs.
