hot lights
Has anyone had problems with halo low voltage lighting?I have installed h1499ic fixtures,1493 trims,50w mr16/fl/40 lamps.All controlled by skylark slv 600w dimmer.Fixtures are getting so hot that trim/lamp info inside can is melting.White trim on one is turning brown from heat also.Awaiting word from supply co rep,just wanted to see if anyone else had similiar problem.Fixture is i/c so insulation is not cause.
