Spacious Ideas
- Oregon
- Electrician
I have discovered a hot neutral in a panel board and at the distribution transformer. A pen tester and two meters confirm around 117v between primary feeder’s EGC and secondary Neutral or EGC. There is no system bonding jumper in transformer OR panel board that I can see. There is only a lug on one side to accept the primary EGC and same on opposite side for secondary EGC (no common terminal block just connected via enclosure).
I know the SBJ needs installed but I want to move forward safely. Also what about circuit breakers and fuses trip/blowing or other problems that may show up after there is SBJ.
Thanks ahead of time for responses.
