Re: Hot Removal and intallation of buss plugs
I'm with you guys on this one.
 Years ago, we used to do tons of hot work on the power gear for a major communications company.  They would have us do the work in the middle of the night when the load was the lowest... in case we blew something up, they could switch to battery back-up and not drain the batteries down as quickly as in peak hours.  I used to think I was a bada** electrician because I could tap hot busses, put on lugs, bus fingers, the works, all while energized.
 Safety glasses, hot gloves, taped up wrenches, and a couple of rubber blankets.
 I cannot believe how stupid I was back then. And I give thanks that I am still in one piece.  All it takes is one loose screw, something to come loose and fall in the buss, something not even related to what you are doing... kinda like russian roulette.
 Never again.
