Have a weird problem. New construction. One 20 amp circuit consisting of about 8 outlets. GFCI outlet at beginning of the run. Tripped and will not reset. Disconnected line and load. Placed ohmmeter on load side. Load side is acting like a capacitor. Meter rings up from 6 Megohms to open circuit. Reverse leads and get the same readings. Circuit works fine with regular outlet in place of GFCI. Any ideas? My guess is that the GFCI is sensing the resistance even though it is very high. I'm going to try splitting up the circuit tomorrow to narrow it down. Any help would be greatly appreciated.
Kevin
Kevin
