doje
- Fremont, CA USA
- Electrician
I’m installing a hot tub on my rear deck. It will be 7’ away from my main panel. Directly in line of site but over the 5’ minimum distance. Can I just feed the hot tub from a GFCI breaker in the main panel or do I need a second means of disconnect?
Side note, I would install a large permanent phenolic label on the panel cover stating “HOT TUB DISCONNECT INSIDE” and label the breaker clearly.
