D domnic Senior Member Occupation Electrical Contractor May 26, 2022 #1 In a multi cable assemblies can the egc be bare , from disco to hot tub above ground . ( single family home)
jimport Senior Member Location Outside Baltimore Maryland Occupation Master Electrician May 26, 2022 #2 Exterior portions of the wiring need an insulated egc.
Electromatic Senior Member Location Virginia Occupation Master Electrician May 27, 2022 #3 Is that the case, or did they change it to only needing to be insulated in corrosive environments?
D domnic Senior Member Occupation Electrical Contractor May 27, 2022 #4 jimport said: Exterior portions of the wiring need an insulated egc. Click to expand... What are calling exterior ? 2011 code article please.
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor May 28, 2022 #5 domnic said: In a multi cable assemblies can the egc be bare , from disco to hot tub above ground . ( single family home) Click to expand... I don't believe you can run cable from the disco to the tub
jimport Senior Member Location Outside Baltimore Maryland Occupation Master Electrician May 28, 2022 #6 Exterior portion, any wiring outside the building environment. Insulated EGC has been required as long as I remember.
