Hi...
I'm going to be wiring an exterior hot tub. I'm thinking about using one of those AC 2 pole pull out disconnects,
https://www.homedepot.com/p/GE-60-Amp-240-Volt-Non-Fuse-Metallic-AC-Disconnect-TFN60RCP/100674085
but I'm not seeing a place to install a neutral block (guess I could splice it,but?) and the wire rating for the lugs looks like it goes 14-8 ( I will be using 6's I think... I think the tub which hasn't been ordered yet might be a 50 amp but if it's 60 then I would need the 6's or if I'm running romex.).. I haven't seen the job yet and the owner wants it all ready for when he gets the tub which he hasn't ordered yet.. But this has me thinking.. I've only hooked up a couple over the years, and can't remember if a disconnect with breaker was supplied with one or what I used.
Which non fused disconnect enclosures do you recommend for a hot tub? I'm thinking I may have to get a disconnect that accepts a breaker to get a neutral bar.??
thank you
thank you
