proelectric
I just installed a Hot Tub that was delivered with an outdoor subpanel that contained a 2 pole 20 GFI breaker and a 2 pole 30 GFI breaker. These serve as overcurrent protection for the heater, pump and controls of the hot tub, as well as disconnecting means. I followed the directions and wiring diagram (for a change)supplied with the unit. It called for feeding the panel with a 50 Amp 2 pole breaker and #8 feeders. I installed it this way and the inspection is tomorrow. I'm thinking now that I should have used #6's. What are your thoughts and if the inspector has an issue, Do I have a defense?
