olly
- Berthoud, Colorado
- Master Electrician
I wired a used hot tub that supposedly worked before they bought it. I did land the load side neutral on the gfci breaker so that's not the problem. When I lift the phases off of the hot tub lugs the Gfi holds. Is that enough to tell me that it has nothing to do with my wiring?
What else could I do to prove that my wiring is not the reason the GFCI is tripping?
Thank you.
Thank you.
