kkwong said:2. No local ammendments-Yes to the disconnect within 5' and 120VAC recep.
infinity said:For a single family dwelling the disconnect needs to be within sight (50') or part of the package unit itself.
2008 is unchanged from 2005.Len said:2005 code requires disconnect 5' from hot tub.
680.41 Emergency Switch for Spas and Hot Tubs.
A clearly labeled emergency shutoff or control switch for the purpose of stopping the motor(s) that provide power to the recirculation system and jet system shall be installed at a point readily accessible to the users and not less than 1.5 m (5 ft) away, adjacent to, and within sight of the spa or hot tub. This requirement shall not apply to single-family dwellings.
kkwong said:but is 50' really line of site? I can't tell if my disco is thrown from 40' let alone 50'.
JohnJ0906 said:But you CAN see if someone is trying to turn it back on while you are working on the equipment.
Yeah it's off, I think. Go ahead. It should be safe...kkwong said:Me thinks we need some more info...
I do agree that the 5' rule is for commercial, but is 50' really line of site? I can't tell if my disco is thrown from 40' let alone 50'.
I actually did this with a friend who is a journeyman as well...the 120vac receptacle was not installed, as there was one about 15' away GFCI protected. I put the GFCI disconnect at 6' away, and it worked without a problem...what is the deal with the general use receptacle? I interpreted the code to be neccesary if the equipment utilized it, then it was required...local code issue?bradleyelectric said:are you doing this by yourself as a new tradesman?
1. thank-youkkwong said:1. Welcome to the Forum
