Re: Hot tub near panel
(C) Switching Devices. Switching devices shall be located at least 1.5 m (5 ft) horizontally from the inside walls of a pool unless separated from the pool by a solid fence, wall, or other permanent barrier. Alternatively, a switch that is listed as being acceptable for use within 1.5 m (5 ft) shall be permitted.
can a panel be called a switching device ?
note this is not a pool
[ May 12, 2005, 08:00 PM: Message edited by: jimwalker ]
