bassbug2003
I have been in HVAC-R service work for a long time, but not a lot of installs. I'm installing a spa for a friend, 50 amp main panel breaker, a 50 amp "Swan brand" GFCI panel by the spa. I've run 3 # 8's, 2 hot and a neutral,and a # 10 ground. The run is under 50 ft. Could you tell me if this ground is big enough, and do I need to drive a ground rod to land at the ground strip in the spa box.Main panel to spa panel is PVC, and spa panel to spa is mettallic sealtite.This is probably the best web site of any subject I have interest in, glad it's here. Any help is appreciated. thanks, bassbug
