ashtrak said:
I have a hot tub job coming up and the owner wants a concrete pad. I have not as yet wired an outdoor tub. What type of bonding do I need in the pad and how do I terminate it and where? Thanks
Being immersed in water that is touching a pump and heater powered by 240 Volts is serious business.
The requirements are too much to type in here. You really must get Article 680 of the 2005 NEC and spend an evening or two studying it.
If fact, if you are doing electrical work for pay, you should own the code. You can often get one on that auction site for about $50. You can also read but not print the 2005 code on the NFPA site.
NEC Article 680 covers everything from before the pad is poured through installing the lights and outlets for the wet bar. You should also have a chat with the electrical inspector before you pour concrete. Grounding the pad and all the other things are not cheap and mistakes in concrete are hard to erase.
The going price for electrical work for a simple spa/outdoor tub on a deck around here is $1000 to $1200. That doesn't include the special costs of concrete pad and bonding.
