sd4524
- Southern California
I looked at a job yesterday at a rental house for a property manager. Tenants say that if they stand barefoot in backyard and put hand in hot tub they get a shock. When they turn the main breaker off then they don?t get a shock. This started about a month ago right after an old hvac unit was removed from under the house. I checked all of the hot tub wiring (new) and it was done properly, connections were tight, voltages o.k., bonding of motor, h20 pipes done right. I megg?d the wiring from panel to disco and the wiring from disco to hot tub- no problems.
I checked the voltage at main panel and had 120 to ground on both L1 and L2 and 240 between L1 and L2 with all ckt?s turned on. # 4 ground wire goes under house and I was unable to determine what it goes to. There are quite a few mwbc?s and the only other 240v load is an oven. I went under the house briefly and it was a complete abortion- wires lying on ground, open j boxes, open splices, some k and t, some romex, some old bx, the 240 oven (#6) is splices in a j box that?s too small. Still couldn?t see where the main ground wire went to. It eventually got too dark to see so I told them I would be back early next week.
Here is my plan:
1. Install ground rod and bond to water pipes if not already done.
2. Pull meter and check for loose neutral, check overhead utility connections
3. check all mwbc connections
I?m thinking that when old hvac unit was removed from under the house maybe a connection was damaged.
Besides sticking my hand in the tub with no shoes on what is a good way to test if problem is gone? Any other suggestions? What is most common cause of this problem? If I call sdg&e I want to be sure that I have check'd everything possible first.
Here is my plan:
