olly
- Berthoud, Colorado
- Master Electrician
Can someone help me understand why #8 CU can be used for a hot tub on a 50A breaker. 110.14 (C)(1)(A) says you have to use the 60* column. I have not wired many hot tubs. When someone wants the wiring in before they have the tub would you run #6 CU to be safe or is #8 CU standard?
I assume #8 can be used because the hot tub is only pulling 40A? But I am guessing. Please let me know
