Hot Tub wiring 240 VAC
kc61
New member
Eastern Kansas
This is how I was planning to wire my new Hot Tub. Any comments would be appreciated.
1. Install 50 amp breaker in panel
2. Run inside 6/3 wire from panel, drill through concrete wall, and run 6/3 through wall into the back of the disconnect/GFCI
3. Run 1" rigid PVC from the disconnect to the back of the hot tub, then transition to Seal Tight to enter the tub.
4. Pull 1 red, 1 black, 1 white #6 and 1 green #8 through the conduit to the Spa panel and make connections on both ends
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
