T triplex15 Member Location Virginia Mar 12, 2012 #1 Where in the code does it tell you that the Hot Tub wiring from the electrical panel to the outside disconnect needs to be in conduit?
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor Mar 12, 2012 #2 triplex15 said: Where in the code does it tell you that the Hot Tub wiring from the electrical panel to the outside disconnect needs to be in conduit? Click to expand... Well it does in 680.42 unless it is a one family dwelling (C) gives the exception. Be aware that some tubs require a full size EGC and that would require a conduit.
