Hot Tub wiring
johngreger
New User
CT
Ok so wiring hot tub question. Wiring from Panel in garage to hot tub on patio. Plan because of layout, is to run MC 6/3 with insulated ground from panel to to junction box, At junction box splicing in AWG 6 THHN (for outside run above ground along foundation) through conduit to the GFCI disconnect. From there I will use liquid-tight to hot tub as you would expect. My question as, I have heard mixed things, can I run the MC from panel to PVC junction? My thought was no as I was under the impression that i could not, however I was told this can be done. I want to know that info is correct as I would then plan to use a PVC junction and run the THHN through a PVC conduit to the disconnect.
Thank in advance for any assistance you can offer.
