Hot tub wiring
Ud56
New User
New York State
Optician
Running wire from main in basement,outside to disconnect for hot tub. 60a square d breaker in main. Run is approx. 107 ft. To disconnect which will have a 50a for hot tub and a 20 a breaker for outlet for general use. Not sure on wire size. Did the math and for that run the voltage drop with #6 thhn is about 2.7%. Going to run thhn through basement in emt to out side in sch. 40 to disconnect. Breakers are rated 60/75 deg. So I sized the wire according to nec table for 75 degrees. I can’t get the electrical inspector in my area to get back to me so I’m relying on the forum. Is #6 going to pass inspection or should I go to #4. Also concerned about the distance. Just a side note doing it myself is saving me approx. $950 from what I was quoted. Thank you very much for any answers!
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
