caosesvida
680.25 B. 2 Separate buildings , where insatlled a separate equipment grounding conductor shall be insulated. I am thinking #2 urd with #4 rr, direct burial aluminum to a subpanel in the mechanical room, nar the tub, then from the a sub panel to the hot tub, with a 40 amp gfci 2 pole. There will be a 120 load, I will run 4 wires all copper to the hot tub in conduit (non- metallic) to the junction box.. Am I ok with this setup? the hot tub requires a 40 amp circuit. I don't do residential very much, or hot tubs, this is a residential situation. Not sure if I am missing something. All conduit to the hot tub, but to the sub panel I can use urd 24" deep. This would cover the insulated grounding conductor. thanks for any help.
