frogneck77
- Shelton,CT
Anyone hear of a code requirement for a disconnect on a hot water heater?
You betcha. Within sight and within 50 feet. Sometimes the breaker in the panel is sufficiently close to qualify.frogneck77 said:Anyone hear of a code requirement for a disconnect on a hot water heater?
Sure you could, you just didn'tstickboy1375 said:Yeh, its an appliance... :grin: And its not a hot water heater, if the water is already hot then there is no need to heat it.. sorry I couldn't resist...
I knew I would get the usual treatment for asking a dumb question, but I couldnt help it. In the 13 years Ive been wiring houses Ive never had to install a disconnect on a Cold water heater.Conversing on this forum helps me take my brain out of autopilot quite often-Thanks for the laughs and all the great info-I really respect all of your opinions,the occasional spark of wit is entertaining as wellstickboy1375 said:Yeh, its an appliance... :grin: And its not a hot water heater, if the water is already hot then there is no need to heat it.. sorry I couldn't resist...
frogneck77 said:I knew I would get the usual treatment for asking a dumb question, but I couldnt help it. In the 13 years Ive been wiring houses Ive never had to install a disconnect on a Cold water heater.Conversing on this forum helps me take my brain out of autopilot quite often-Thanks for the laughs and all the great info-I really respect all of your opinions,the occasional spark of wit is entertaining as well
Some never miss an opportunity to crack wise.frogneck77 said:I knew I would get the usual treatment
Minuteman said:Some never miss an opportunity to crack wise.
I like breaker locks a whole lot better than installing a small disconnect (Or I have seen some install a 3 wire dryer outlet).
stickboy1375 said:I highly doubt a cord on a water heater is legal...
480sparky said:No one has stated it's an electric water heater... suppose it's a gas w/direct vent?
stickboy1375 said:but what do I know?
I've seen that too, but that's not legal. A 3-wire dryer rec is 120/240 ungrounded, and for a water heater you'd need a rec for 240 grounded.Minuteman said:(Or I have seen some install a 3 wire dryer outlet).
mdshunk said:I've seen that too, but that's not legal. A 3-wire dryer rec is 120/240 ungrounded, and for a water heater you'd need a rec for 240 grounded.
stickboy1375 said:I would go with that the Water heater is not listed to be cord and plug connected... :wink:
422.16 Flexible Cords.
Dennis Alwon said:Marc, what difference would that make. Isn't the 3 wire dryer ground terminal grounded to the metal of the receptacle?
