By code, do I need to install a local disconnect switch for a 240v Electric Hot Water Heater?
OK, since you're new here, I'll let you in on The Electricians' Biggest Secret: You don't need to heat hot water. :grin:
Anyway, welcome to the forum!
Come to my house and you may not say that.:grin:
Strange my water heater comes on when the water is still hot, I guess you let yours cool off entirely.
What do you do, leave the breaker lock installed permanatly
The provision for locking or adding a lock to the disconnecting means shall be installed on or at the switch or circuit breaker used as the disconnecting means and shall remain in place with or without the lock installed.
OK. You got me. Sorry I mis-spoke.
Some townships in NJ are making the plumber install a local disconnect when replacing the water heater. Why should a disconnect be installed if a breaker lock will suffice?
I agree with the misinterpertations! Thanks for your help
Huh?You agree the interpretations are correct, or that they're not?
I believe that he's agreeing with me that officials here have their fair share of misinterpretations of the code.
