Good morning!
Im working on a 4-story hotel project. The suites in this hotel HAVE a permanent range and therefore meet the definition of a dwelling unit. My question the load calculations for the panels.
Im required to circuit the building similar to a prototype that I was given which basically has two panels per floor, and then all the branch circuits get routed back to just a couple of panels and therefore the little dwelling units do not have individual panels. These same panels would also feed the common area lighting.
My main question is; Am I permitted to use the Dwelling Unit Optional calculation and all of the associated reductions?
(ie. 2VA / sq ft for lights & recepts, 10 kW @ 100% + remainder @ 40% + HVAC) + Common area lighting @ 100%. THEN Im assuming I would use the demand factor listed in 220.84 for this connected load?
(or)
Should I use 2VA / Sq.ft + All Loads @ 100% + kitchen equipment @ 65%? I would probably prefer to do it this way but this would likely result in an over-sized service.
Thanks in advance.
(or)
Thanks in advance.
