fraymond
- Huntsville, Alabama
I was going to put GFCI receptacles in all locations. GFCI's too big for the box so I decided to use a SQ D QO series GFCI (no arc flash). Only one 100W lamp plugged in. When lamp is turned off breaker remains reset. Turned lamp on, breaker trips, Turned lamp off breaker will reset. Checked resistance at breaker, 45ohms. Turned lamp off... open circuit i.e. infinity. Moved GFCI breaker to different branch... same results!?!? Put original standard breaker back in... no problem. House had an addition added. 100A service in garage with another breaker panel added in hallway. I looked in the garage panel and saw a piece of romex that was added going to a GFCI breaker (blue plastic box). I suspect the GFCI is grounded. Was going to disconnect tomorrow to see if this would make a difference. Any thoughts please...
