House door alarms for pool
bth0mas20
Maryland
I have a customer that an inground pool installed. They have asked me to install door alarms on the house doors that access the pool fenced in area. They claim to have been told by the AHJ that its needed. Ive never heard of this can anyone clairify it for me?
augie47
Tennessee
There are pool alarms on the market for child safety. They are now required for new pool installs in TN.
I suspect a misunderstanding.
bphgravity
Florida
Pool & spa barrier requirements are typcially a component of your local building code or state statute.
For example, the International Residential Code section on swimming pools states:
9.2. Doors with direct access to the pool through that wall shall be equipped with an alarm which produces an audible warning when the door and/or its screen, if present, are opened. The alarm shall be listed and labeled in accordance with UL 2017. The deactivation switch(es) shall be located at least 54 inches (1372 mm) above the threshold of the door...
The Florida Building Code for example, has extremely stringent pool barrier requirements located in Chapter 41 of the FRC & Chapter 4 of the FBC.
renosteinke
NE Arkansas
Apart from code / AHJ issues, this is also a matter that greatly affects your ability to get homeowners' insurance. Lack the alarms or barriers, and you'll find fewer carriers, higher rates, and more exclusions.
(I just got my hands on some 'insider' info that is proving to be a real eye-opener on this topic!)
Remember, we don't simply follow the NEC, to the exclusion of all others. There actuall exists a 'Swimming Pool Code,' which is broadly adopted by communities. In essence, the pool needs both physical barriers to entry as well as alarms to indicate when the barrier is breached (say, by a gate opening).
