bakerbrotherselectric
We are finishing up on a house re-wire on a house built in 1930. Converting the house over from knob and tube to romex. The house has already had a upgraded service installed 2 years prior.At the time of the new service install, a 50 amp subpanel was installed in the detached garage. They ran a 1 1/4" pvc conduit under the house to a 6x6 nema 3R junction box on the other side of the house.From there it went under ground to the garage. In the same 1 1/4" conduit they ran the 6 circuits that feed the house(9-12 awg.) to the 6x6 junction box. From the 6x6 they piped up the side of the house to a 2 gand wp box, and spliced onto the old knob and tube wires. I have some questions?
eg.
He has (2) 20amp circuits that feed his kitchen. 1st 20amp feeds (2) countertop recept. 1 dinning room recept. and the disposal. 2nd 20amp feeds gas stove, space saver micro, refer, and bathroom light. DW is fed from the 20amp living room circuit.
-In this case, when re-wiring the house is it required to add additional circuits called out in the code for specific rooms? Do I need to run a dedicated circuit to the disposal, a dedicated circuit to the DW, and install arc fault breakers for the bedrooms?
eg.
