mshields
- Boston, MA
What, if anything, defines how far off grade a house keeping pad may or should be? How about how far that pad extends beyond the equipment. I'm thinking of concrete pads on grade - outdoors. Not inside.
One related point that was raised about storm damage remediation is that where equipment is required to be mounted far above grade to be above the flood plane, you have to make a pad wide enough around the equipment to provide the required working space without having to stand on a ladder. Climbing a ladder to get there is fine unless you have some component which is required to be readily accessible.What, if anything, defines how far off grade a house keeping pad may or should be? How about how far that pad extends beyond the equipment. I'm thinking of concrete pads on grade - outdoors. Not inside.
This term is new to me. Please tell us about "housekeeping pads."
