macmikeman
- Planet macmikeman
emahler said:mac,
am i correct in thinking that there is an existing 100A MCB disconnect at the meter, feeding an existing 100A MLO panel in the house. And that you want to add an additional MLO panel at the other end of the house?
why not replace the existing disconnect with a 4 ckt panel. put in the 100A CB and a 60A cb?
you have less than 6 means of disconnect, you aren't pigtailing, each is it's own feed...
code wise..i didn't look it up, so have at code guys.
would this work for your app?
Erik, You are right about the existing setup, but it is a 100 amp rated meter/main socket. There are two unused spaces, however adding a 60 amp to the existing 100 amp breaker in that existing can would be IMO a different code problem. I could do the calculations, split this up to a 60 and a 40 and be done with it I guess, however I know for a surefire fact that just re-routing all the existing branch circuits from the old location to the new spot will meet code . ln this case that's going to take a bit of finesse and labor. A kitchen panel would have made this a bunch easier. Without a doubt a new 200 amp service would be the best solution, but imagine a 150 foot concrete driveway poured over an old hardened lava field and then multiply that by my excessive need for Charge Large for this kinda headache, and you will see why the property owner would prefer I could find a solution using the existing service.
