dezwitinc
- Delray Beach, FL
dezwitinc said:
Dennis Alwon said:All this item seems to do is take 120v from 2 different phases.
dezwitinc said:Your first born?
I don't see why you say neutral current. But I see where current would flow on the transformer primary EGC's to thier source to complete the circuit.iwire said:But if they happen to use this in a building with multiple transformers and end up connected to different transformers the neutral current flow will end up on the EGCs.
Is this correct? If I had 1 phase from 1 transformer, and another phase from a different transformer, would there have to be a physical connection between the 2 tranny's for 240V equipment to work?chris kennedy said:But I see where current would flow on the transformer primary EGC's to thier source to complete the circuit.
Bob the devices in Dougs OP are NEMA 6-15R's. There is no neutral.iwire said:There is a connection, the EGC.
Lets say you have this box hooked up across to different single phase SDSs.
Now lets say the load was 15 amps on 'A' and 5 amps on 'B' that would mean the neutral will have 10 amps on it.
That 10 amps will go both directions on the neutrals and then through the bonding jumper and back to the source.
I do not know what would happen if you happened to grab one phase from a single phase SDS and the other from a three phase SDS.....I am sure it would not be 240 but I don't know what it would be.
I think Smart or Rattus will have to vector this out.
No, but draw two independ transformer secondaries, connect a load from a radomly-selected line on one to a randomly-selected line on the other, and then trace the complete circuit.chris kennedy said:Bob the devices in Dougs OP are NEMA 6-15R's. There is no neutral.
Probably something akin to the various voltages available between terminals in the devices-from-different-systems-in-one-box discussions.iwire said:I do not know what would happen if you happened to grab one phase from a single phase SDS and the other from a three phase SDS.....I am sure it would not be 240 but I don't know what it would be.
LarryFine said:Probably something akin to the various voltages available between terminals in the devices-from-different-systems-in-one-box discussions.
LarryFine said:No, but draw two independ transformer secondaries, connect a load from a radomly-selected line on one to a randomly-selected line on the other, and then trace the complete circuit.
You will see that there must be a connection between some conductor on one secondary and some conductor on the other. This would most likely include the intentionally-bonded neutral of each secondary.
chris kennedy said:I see Larry, thank you. Picture worth a thousand words.
