donf
- Tidewater Virginia
The light fixture has a lip that prevents the replacement of the bulb. I cant find anyway to pivot the fixture to gain access to the bulb. Can you help?
What is this?
What type of bulb, fluorescent tube, pin based, screw in, etc?
Little more info would help.
It's some kind of indirect lighting. Did you see if the trim piece or frame will pull off? It may be held in by spring clips. What happens if you jiggle it? Does it move at all?
If none of that works look for some plugs that are hiding screws.
It just seems dumb to have to pull the whole fixture out to change the bulbs.
It is likely built as 'vandal resistant'.
What type of lamps, diameter, length, etc? Can you grab them and twist or pull or anything? I once ran into some 4 foot fluorescents were the lamps went straight in without twisting.
