I was recently called to a job for a bath remodel. I found K+T spliced to 2 wire romex in the wall that led to a single pole switch, hot and neutral were landed on respective screws. This switch was in an adjacent room and controlled a recep above the ceiling that a florescent shop light was plugged into. There was only the one romex in the switch box, the power coming from the wall splice. At the recep in the ceiling was K+T with the hot and neutral landed on respective screws. I only know that when I got there the fixture was working and I could turn it on and off with the switch. I put a meter on the 2 wire romex that was leading to the switch(traveled thru finished wall about 6 ft)and confirmed it was the line going to the switch.I made the proper repairs to the bathroom and deleted the K+T that was in there, but can't figure out how the switch ever worked. Seems that when the switch would be turned on it would ground out immediatetly to the neutral conductor. Any Thoughts?
