Just wanted to toss a few things into this thread - and say
Hello!!! :smile:
(it's been a long time since my last post!)
The information is in addition to the great information already posted by the other members.
Anyhow, as to Dynamic Braking, there are two definitions:
- Regenerative Braking: When a DC Motor has Electric Braking applied to it, via regenerative actions,
- Dynamic Braking: When an AC Motor has Electric Braking applied to it, via DC Current injection.
The first method - DC Regerative Braking, is when the DC Motor is used as a Generator, typically when a large dynamic load is connected to the Motor, then Line Current is removed from the Motor's Terminals, but a small value of Current is driven into the Field Windings, to keep the Magnetic Field established.
That "Braking Current" may be regulated per the intensity of the Braking required.
With the DC Regenerative Braking, the DC True Power generated by the Motor is sent to a "Braking Resistor" (or an array of Braking Resistors for heavy usage situations).
The True Power developed by the DC Motor is converted into Heat Energy, at the Braking Resistor(s) - thus placing a low Resistance load across the DC Generating device.
The Motor slows down because the Kinetic Energy built up in the rotating load is converted to Heat at the Resistor(s) - and continues to slow in a linear fashion per the speed of the rotating load, the remaining Kinetic Energy in the rotating load, and the fixed Resistance of the Braking Resistor(s).
Railroad Locomotives with DC Traction Motors employ this technique for an alternate braking mechanism - used in conjunction with the Locomotive's Independent Air Brakes, and the "Trainline" Air Brakes.
Still termed "Dynamic Braking" by the builders (GE and GM), the Locomotive has a separate throttle for Dynamic Braking - which is segmented into Eight (8) individual set points - ranging from "0" to "8", for control over the complete Braking application.
The effective range for Dynamic Braking is between 15 and 30 MPH, and so the Dynamic Braking is typically used on grade descents and when stopping a Train.
Locomotives with AC Traction Motors (Motors are driven via VFDs), typically employ an Injected DC to the Traction Motors - which results in a non-rotating magnetic field produced in the stator windings, then induced into the rotor - which quickly retards the speed of the moving rotor (or places a "binding load" on the rotor).
Since the AC Traction Motor will generate some VARs / True Power, a Resistor (or array of Resistors) is placed across the Motor(s) during the Braking application.
That's all for now!!!
