How Do Electricians Control Overspray, etc.?
joe tedesco
110.12(C) Integrity of Electrical Equipment and Connections.
Internal parts of electrical equipment, including busbars, wiring terminals, insulators, and other surfaces, shall not be damaged or contaminated by foreign materials such as paint, plaster, cleaners, abrasives, or corrosive residues.
There shall be no damaged parts that may adversely affect safe operation or mechanical strength of the equipment such as parts that are broken; bent; cut; or deteriorated by corrosion, chemical action, or overheating.
Joe Tedesco
Disclaimer: www.joetedesco.com
charlie
Indianapolis
Re: How Do Electricians Control Overspray, etc.?
Joe, when I was working in the trade (WOW, that was a long time ago!), it was common for me to install a panelboard and remove the bus assembly. I pulled in all the home runs and the service entrance conductors or feeder and reinstalled the bus assembly at finish. On larger jobs, I covered everything with plastic.
It is going to be interesting to see other answers. Charlie
iwire
Massachusetts
In dwelling unit panels I used to put cardboard between the "hooks" for the line side of plug in breakers.
Now on commercial jobs we make it the painters problem, they paint, it they own it, same for devices and plates, although we have had painters clean the devices instead, their choice.
Bob
bennie
Esteemed Member
In this State, the service panel is installed and turned on for construction power, at the start of a dwelling. The panels are covered before any other work is done. Covers look bad, but the interior is usually clean.
Almost all jobs get a service inspection before a wiring rough in.
pierre
The overspraying seems to be a lack of concern for painters and GCs. If we complain the GC seems to think we are nagging him. Also most of the time our switch boxes are in the sheetrock joints, and on some jobs are filled with compound.
On most jobs, we cover the panel, but when we come back for final installation we never know what we are going to find. Removing the guts is a problem, because a lot of times when the final work is performed, the same men may not be on the job and locating the 'parts' can mean a phone call to the supply house.
This seems to be the norm for the 20+ years I have been in the trade.
Pierre
websparky
Cleveland, Ohio
This is how it is addressed in my area also. We inform the GC and the painter.
G
Guest
Guest
Internal parts of electrical equipment, including busbars, wiring terminals, insulators, and other surfaces, shall not be <snip>contaminated by <snip> paint, plaster<snip>
<snip>
Joe Tedesco
That covers it quite nicely, but it would also make sense to codify that the bus must be removed or masked off during the spraying of paint and/or plaster. As a service electrician in 1994 I saw a ton of burnt buses from paint and plaster overspray. It made me a ton of money but it's still wrong and a safety hazard!
Here is another post (scroll to my awwt post): awwt speaks out on bus contamination
images
[ This cybercom was spell checked by ieSpell. Get yours for free at http://www.iespell.com
Hoping for a grammar check for these forum posts too...but don't know where to get that. ]
jxofaltrds
Inspector Mike®
Mike P. Columbus Ohio
ESI, PI, RBO
How? Rip out and back charge.
awwt. No need to codify. Should we require (codify) that the windows get covered?
Funny why they would cover everything except the electric.
awwt. It would be a check in grammer.
Mike P.
G
Guest
Guest
Before I got ieSpell I thought it was grammer too. Somebody busted my chops on that. :D
Main Entry: gram?mar
Pronunciation: 'gra-m&r
Function: noun
Etymology: Middle English gramere, from Middle French gramaire, modification of Latin grammatica, from Greek grammatikE, from feminine of grammatikos of letters, from grammat-, gramma -- more at GRAM
Date: 14th century
1 a : the study of the classes of words, their inflections, and their functions and relations in the sentence b : a study of what is to be preferred and what avoided in inflection and syntax
2 a : the characteristic system of inflections and syntax of a language b : a system of rules that defines the grammatical structure of a language
3 a : a grammar textbook b : speech or writing evaluated according to its conformity to grammatical rules
4 : the principles or rules of an art, science, or technique <a grammar of the theater>
- gram?mar?i?an /gr&-'mer-E-&n, -'mar-/ noun
A
a.wayne3@verizon.net
Guest
Contamination due to paint has become a big problem on several of our job sites.We do maimly residential work and the painters have bought at least 25 panels over the past 3 months.We cover then on rough in but between the inspectors opening them and people using them as shelves for their lunch it is impossible to insure that between all the trades that follow us the panels remain covered.So we backcharge the painter to change the panel guts.They gripe and complain but if they paint it they buy it !!!! After 25 $195.00 backcharges they cover the panels now :D
as a gc the other trades i work with have been my "team" for a while. if i bring in someone new for a job they understand that if they damage someone else's work the buy it. not fix it. this is all put in my contracts and everyone likes it. i don't let the plumbers pull wire tile guys don't set toilets. make everyone on the same page so we can just ***** about who"s turn it is to buy the beer.
al
cwsnsons
We don't have too much problem with the painters. Our biggest ones are: 1. SOMEONE keeps stealing the panel cover screws (you know the funny ones with the oversize Tork or Robinson Square drive heads?)! 2. The drywall hangers playing their version of battleship where they use their Roto-zips to see how many wires they can cut to shreds even when they are tucked as far back in the box as possible. and 3. The drywall finnishers using their "bazooka" to fill all 3 and 4 gang boxes with a quart or two of mud.
Most of these fellows are nice guys, they just don't understand the hassle they make for someone else. If there's an area where another trade points out to us where we can help them by not making it hard for them when they come behind us, I make sure to go over it with my boys (2 sons) so they can be sure to keep an eye out for it and not get in someone else's way. If it doesn't violate code or require me to do their job, we'll happily try to help. But I've had so many finnishers try to explain there's no other way for them to do it!
Websparky / Iwire, how would you address these problems?
Chris
iwire
Massachusetts
For a few nicked wires myself and the other foreman in the company will just deal with it, I am a big believer in corporation between trades and I will just remind the drywallers I have helped them out when I need a favor from them. Maybe we forgot something and need some drywall patched where we fished it in.
However, if it gets out of control the slips come out and the GC gets back charged, as I said before there is language in the contract that makes them responsible for damage.
There is few code compliant ways to fix the wires if they get cut off at the connector, so a professional fix can get expensive.
