RLyons
- Changed for anonymity
First let me start off by saying my commercial experience is limited that being said I got a call to a restaurant I've done some prior work in. New drain lines where being added and while the plumbing company was jackhammering up the floor they did a number on some 3/4" emt that was embedded in the concrete. So since the emt was compromised I proceeded to cut it and trace using a locator. I traced the pipes back to a panel which had just as many abandoned circuits as it did one currently live, an absolute mess. The pipes had live and abandon circuits of which I was unable to locate the far end. I cannot say for sure that the circuits actually do something but would rather re-feed them than wait and see what doesn't work. With the floor already cut open and the fact they are concreting everything but a 3' section of the damaged area first thing tomorrow I ran some 1" pvc and stubbed up with rigid on the wall located directly behind the panel. I see there is no ground wire present so I can only assume the pipe was providing it. So how do I junction the emt to the pvc in a floor? is it even possible to be done legally? They are up my butt to get this fixed so they can reopen and will be totally against further damage to the floor.
