nogard1126
- WI
First I would like to say if I'm not posting this in the right spot, then feel free to move it. I've read through the NEC with some confusion, and also read many things online. In NEC 810 is says that you must ground an antenna, and it needs surge protection which must be grounded, I get that part. I thought the ground would be for lightning, but there is no way a small wire could carry lightning and survive. I've heard these points and they all make sense. That it is done to: prevent static build up, make the antenna the same potential as the rest of the terrain, if lightning does hit it to have only one common path to ground (try to keep energy from grounding through equipment).
I received a grounding kit with one of the antennas I purchased. It consisted of #10 solid coated wire and a simple grounding block that the coax goes into then out of, and there is a place to attach the ground wire to it. This didn't see fully correct.
The way I understand it, if the antenna is installed at a commercial/industrial building with a ground system, then the antenna ground can be attached to this. In 810 it says minimum of #10, but wouldn't you have to use a minimum of #6 per 250 if it is exposed to physical damage? Or a smaller gauge armored ground wire (#10) could be used, but which would be better? Then can this ground enter the building through the roof and make its way to a water pipe, or does it need to go right to a ground wire of the grounding system?
In a residential antenna installation I've heard of pounding a separate ground rod for the antenna, running #6 stranded from the antenna to the ground rod and then also bonding this new rod to the existing electrical rods, if this is the case what size wire is required for the bonding between the rods?
If an antenna was installed on a metal mast anchored in the ground, couldn't this be used as the ground if everything was bonded together?
Could someone please give an example of the proper way to ground an antenna in a residential and commercial/industrial environment? Thank you.
