junkhound
- Renton, WA
- EE, power electronics specialty
was going to reply the other thread with this statement but rhe thread closed?
anyway, 40 years ago had to design a ground fitting for nuclear missile silo that not only handled over 300,000 amp 'fault' currents but also had a 60 dB attenuation of up to 100 megaHz signals. 3" dia flange, 3/4" stud. So critical that If there were chatter machining marks on the mating surfaces the 100 MHz requirement could not be met. Needed to have near mirror perfect mating surfaces.
Anyway, fault current testing was conducted and minimum clamping force determined by imbedded strain gauges, but very expensive or difficult to field implement the strain gauges. Found that a simple sample test of the torque to force could be done by placing 3 pieces of 1" length solid solder between the surfaces. Torque ( well over 100 ft-#) and measure the thickness of the solder. Installation procedure was to perform the solder test ever dozen or so installs to verify that installers were maintaining consistent lube and torque calibration.
