How do I control "Metal halide fitting"
I am currently relighting an old portion of our facility and we are leaning toward zone controlling the lighting by means of a PLC, The work will be handled electronically and it will give plant management to option to turn the light off remotely without even entering the department in question. Initial investment on PLC selection is high at first but the mechanical failure will be reduced long term. In conjunction with the PLC, we are using a Total control touch screen at the main panel for supervisions intervention, this same application is going to handle the heating controls for this building as well. You may want to consider getting the MH out of there also, take a look at the new high bay fluoresces available the savings are huge, and the lighting is excellent. You can reduce your new circuit design as well. The have come a long way with the electronic ballast and the T5 and T8 lights as well. One more bit to think about the EPACT Tax rebate are something to consider also well using the HBF, Any bean counter will give you their full attention with these type of numbers.
LHarrington
