jucesanc
- California, Bay Area
I have a 3000 HP, 4 kV, 1800 RPM, and frame 8010 induction motor. If a magnetic center indicator is not an option, how would you determine the magnetic center?
Does that correspond to the top dead center position of a gasoline engine?
I'm sure I did know this as a student eons ago. Our lecturer was an electrical machine designer and taught us all sort of things like short cording and stuff.I have a 3000 HP, 4 kV, 1800 RPM, and frame 8010 induction motor. If a magnetic center indicator is not an option, how would you determine the magnetic center?
I still have the notes but I'm too indolent to look through them.
I've dealt with induction motors most of my working life and never needed to check this. So I'm curious to know why you want to............
How you "find" it is to couple the motor to the load and rotate it, then let it come to a rest, it will always rest in the mechanical center because of slight tapers in the bearing designs to allow for lubrication etc. Mark the shaft position. Then uncouple it, removing the coupling completely from the motor (to give it some space to move) and re-start the motor, marking where the center moved to while it is running (taking proper safety precautions). That is your MAGNETIC center.
For those who don't regularly deal with large AC induction motors, the magnetic fields created by the stator windings don't always match up to the mechanical center of the motor, meaning front-to-back center (not the rotational center as implied in the TDC question). That mismatch is then exerting an axial (parallel to the shaft) thrust on the rotor, a deflection forward or backward depending on where that magnetic center is. As noted, this is ONLY a concern with horizontally mounted sleeve bearing motors. Ball bearings have a race that they run it, so the motor is mechanically held in it's mechanical center. But with sleeve bearings, that axial thrust means you need what's called a "thrust bearing" in the motor or the machine it is connected to. Knowing how much defection exists between the mechanical and magnetic centers will determine what the equipment designer has to deal with in axial thrust.
No, but the information wouldn't really be useful. The PURPOSE is to determine the deflection of the axial thrust. For that, you need to know both pieces of information. In your case, since you are replacing an existing motor, that information is actually somewhat critical (again, assuming it is a sleeve bearing motor, and if the old one had the indicator, it was). As someone explained to me once on a 3,000HP blower; do you want 3,000 horses pulling your motor shaft away from the blower coupling, while the blower is using 3,000 horses pulling the other direction against the same coupling? Even though the deflection may only be a few hundredths of an inch, force is force. you are going to want EITHER for the new motor to have the center in the same place / direction as the old one, or to come with its own thrust bearing built in. If it has the thrust bearing built into the motor, you probably don't need the indicator or to know where the magnetic center is.Is it necessary to find the mechanical center before you determine the magnetic center?
