Bugman1400
- Charlotte, NC
This is place holder for Phil to teach how an induction motor can generate kW without a prime mover.
???This is place holder for Phil to teach how an induction motor can generate kW without a prime mover.
The speed of an induction motor is generally less than that of its rotating magnetic field of the stator. But if the rotor is made to run at a greater speed due to stronger wind as in windmill applications, electrical energy is generated and fed into the grid by the induction motor now acting as a generator.how an induction motor can generate kW without a prime mover.
Is the wind not a prime mover in that scenario?The speed of an induction motor is generally less than that of its rotating magnetic field of the stator. But if the rotor is made to run at a greater speed due to stronger wind as in windmill applications, electrical energy is generated and fed into the grid by the induction motor now acting as a generator.
Energy can neither be created nor be destroyed but may be converted from one form to another and in this case energy in the prime mover (wind) to electrical energy. :happyyes:Is the wind not a prime mover in that scenario?
Look at the opening post.Energy can neither be created nor be destroyed but may be converted from one form to another and in this case energy in the prime mover (wind) to electrical energy. :happyyes:
no prime mover
An induction machine driven above synchronous speed by an external source of mechanical power.
OK, I accept it. What is the external source of mechanical power (prime mover)? Or, is there something else that allows the motor to generate kWs?
I do not disagree with that, but pretty sure that is not what this thread is about.Energy can neither be created nor be destroyed but may be converted from one form to another and in this case energy in the prime mover (wind) to electrical energy. :happyyes:
Then surely Bugman1400 must be joking!I do not disagree with that, but pretty sure that is not what this thread is about.
I'm pretty sure this thread is a spin off from an off topic comment in another thread.Then surely Bugman1400 must be joking!
So how does an induction motor generate power that it did not already put into the load without a prime mover acting on that load, and how is wind driving a propeller not a prime mover in such an application?
Agreed.....the question still remains how can an induction motor generate kW without a prime mover. And no, I am not counting during coastdown from the inertia of the rotor, its shaft, and whatever inertial mass from the load.
Prime mover = "an external source of mechanical power"
What part of this is what you don't understand?
Prime mover could be wind turbine, water turbine, diesel or gas engine, tidal pendulum, giant rubber band stretched on a wooden spool, 1 million hamsters on an exercise wheel, anything that makes something rotate that can be coupled up to the shaft of the induction machine.
I like "You drop the barometer from the roof and measure the time it takes to hit the ground."how can an induction motor generate kW without a prime mover
You sell the induction motor and buy a big pile of batteries and an inverter ? Nothing mechanical moving, so fits the definition ?
Akin to the famous physics test question: How do you find the height of a skyscraper with a barometer?
Ans: You knock on the building super's door, say: "hey, I'll give you this keen barometer if you tell me how tall the building is" !
